The rear trailing arm studs are stripped. It seems like I read they should be drilled out & helicoiled with coarse threads 5/16-18. Is this correct? The studs I have found are coarse on both ends I don't think this should be a problem. Should I replace them all or just the bad ones? If I just replace the bad ones I'll just have fine threads on some & coarse on the others. Should I use loctite on the studs going into the helicoil?
Thanks
Jeff
Thanks
Jeff
