It has been my experience that tying the car down using the frame (in whatever combination) puts a static load on the wheel brgs in only one spot on only one or two rollers. Add the bumps and bouncing of the trailer and that increases the load. Knowing the quality, or lack thereof, of some of the after market brgs, you may end up with a flat spotted or crushed roller. No joy.
Use tire slings on all four wheels and add a chain or strap front and rear with enough of an angle in the strap to allow the car to move up and down but not forward/backward.
As stated above, check at 10 miles, 50 miles, 100 miles, and every time you stop.
Also check trailer tire pressures as low pressure will allow the trailer to wag like a dog's tail. I had one wagging so badly that the trailer tires were coming off the ground. You also need at least a 100#s load on the hitch. Adjust the car location to acheive this.
Jim
