AUSMHLY
If your trafficator does not click off after a short turn, there may be two reasons.
1. It needs to be rebuilt
2. User error.
I fall under user error.
It seems that when I changed my steering wheel and put the trafficator back in, I did not line up the canceling plate correctly on the bottom of the trafficator.
If you put the canceling plate on the top, under the exterior flip lever, the distance is greater for the canceling plate to get to the two pins on the bottom of the trafficator.....duh.
Once I move the canceling plate to the bottom, the steering wheel did not have to move as much for the canceling to occur.
I'm humbling sharing this information in case others wonder why their directionals don't click off after a short turn.
If you want to check your unit, here's the breakdown of what you need to do. The photos will be in the same order as the directions.
1. Makes sure you have enough wire available to be pulled up the steering column. You'll need just enough to pull the trafficator out enough to see the unit.
2. Unscrew the 3 set screws on the steering wheel hub.
3. Pull the trafficator straight out and look at the top of the trafficator. You should see the two springs.
4. Look at the bottom of the trafficator, you should see the canceling plate dead center.
5. If 3 and 4 are not correct, like mine was, move the canceling plate to the bottom.
6. Push the unit back into the hub and tighten the 3 set screws.
Test drive the turn signals and celebrate with a WOO HOO.
Cheers,
Roger
2. User error.
Cheers,
Roger
---TH!--- :laugh:
