Tinkerman
She who is to be obeyed has left gone for 5 or 6 days. Hoo boy no interruptions, I will get the TR-3 engine back together this weekend, YEA. All the preliminary work has been done, parts bought, machine work. I cleared a work spot, got out the manual and got started. I set the bearing halves into the block, lubricate them, pick up the crank, heavy but not terribly bad, and set it in place. Yea! One small step for the tractor engine and one giant leap for this mankind. Go to the work car for my camera, got to photo document all of this. Not in the car! Must have left it at the office, ah well no one cares about the pictures anyway. So back to the crank, try to turn it, wont turn? If it's seated in the journals it should, all the other engines I have done did. Well I look and see a space between the crank and the bearing, ah not seated, I'll just take it out and try it again. A little heavier but still not too bad. So I keep fiddling with it and ya know, after 5 or 6 tries that crank weighs a ton. May have to go see the chiropractor Monday. Be smart, says I and call a friend that has an engine shop. He will come over and take a look at it for me, Tomorrow. arrrgggghhhh
Oh well I shall be stoic like my boxer and start on the head. Same deal, parts bought, prep work done, valve guides set in place. I'll just put it on my work bench. Ya know what, the head is made of VERY heavy cast iron. Managed to get it on the work bench, two visits to the chiro man.
So I get out the intake and exhaust valves, intakes go in fine, exhaust are tight. two of them wont go in, sigh.
So my questions are: Do the valve guides have to be honed? Why wont the crank seat right? How long will my back be out of whack?
By the way the bearing caps fit the crank journals fine when it is out of the block.
Many thanks for all of your help.
Cheers Tinkerman
Cheers Tinkerman
