TR2/3/3A Traction Bars on TR3
karls59tr
Bronze
I saw these on Ebay....supposedly a British Leyland Factory competition option. I'm wondering what affect traction bars would have on a TR3 other than keeping the back wheels from hopping. Wouldnt they have a negative affect on hanging the rear end out in corners? Anyone ever had these on their 3?
I have a set but haven't installed them. See the traction master site for how they work https://tractionmaster.com/ as they are the mfg.
Sunbeam Tigers used two types LAT5 and LAT6. On gets a bracket welded to the frame at the front of the leaf and the LAT6 https://www.tigersunited.com/resources/parts_service/pp-lat6.asp uses a clamp around the spring.
Mine will be on my TR4A solid axle.
They are rare but could be fab'ed with heim joints to be made adjustable.
These bars can do two things, depending on how they are built. They can stop axle hop - and often use rubber buffers that bottom and stop or limit the axle twist. Pinion snubbers do the same thing. They can also more effectively limit spring wind up (the leaf ends up looking like a shallow 'S'), but only if actually attached to the diff by welded brackets and you cn only do that by making the axle free to slide between the spring plates, or you end up with the leaf and bar fighting each other.
Probably nothing is required on a TR-3 - I certainly never bothered with any such measures as you don't get that much of a problem unless you are drag racing, and if that's what you are doing to a TR-3 you would be clearly beyond any help.... :smile:
