Wedge TR8 woes - coil replacement question
tdskip
Ignition woes - Part 4.
I'm trying to completely nail down why she will not run over 4,000 RPM.
Since her ballast resistor line has been cut, I replaced the existing Lucas coil 22-C-12 with a new Lucas Sport Coil.
Well, the new coil sure looks a lot better but, of course, it runs even worse now. Now she won't run over 3,000 without breaking up badly. Really badly.
Ideas?
Tosh
tdskip,
I haven't been paying close attention to this thread but I'll toss in 2¢ worth anyway. I noticed that you are having difficulty sustaining a clean "pull" > 3000RPM.
In my experience breaking up at higher RPM's has usually been caused by a fuel (starvation) problem.
Be sure (if you haven't already) that the fuel pump, fuel filter and the carb jets are all allowing the correct amount of gas into that 3.5L block of cast aluminum.
keep 'on
T
tdskip
Hi Tosh - thanks for the fast response.
In theory the fuel flow issues should be solved at this point since I had the hacked wiring, aftermarket fuel pump, and dead original internal fuel pump replaced with a new one and proper wiring.
I haven't independently checked the flow - and think I should just to double check.
The way she breaks up is almost like a rev limited cutting in, and it does it regardless if I'm light or heavy on the throttle.
With the old 22C12 coil she wasn't happy rev'ing over 4,000 but she would just run out of pulling power rather than breaking up badly. That leads me to think ignition.
I will check the fuel flow to make sure that isn't the problem - thanks for the good idea!
RSMTR8
Sounds like a bad ignition to me...........but check your fuel filter to make sure it is not getting clogged. I had a similair problem once, and it turned out my gas tank was rusting and clogging up the fuel filter! And the car would just putter out!
The Ballast on these cars RARELY go bad!
Rod
T
tdskip
Thanks Rod - the fuel filter was just swapped out and looks good so I don't think that is the problem.
I'm thinking I should put a new Lucas 22C23 coil in, but no one seems to carry them.
Tosh
tds,
Try running the car in a dark garage at night to see if arcing (crossfire) might be an issue. None is best and you can usually see some but too intense is definitely not good.
Have you checked the floats for soaking?
Have you checked the carb linkage (I'm assuming twin Strombergs) for synchronicity. My '6' linkage would slip as the throttle shafts rotated open. Result; one throttle plate open, one not open...not good for running above 2000rpm.
The rev limiter analogy is a good one. "Rev limiters" on our daily drivers function (among other things) by interrupting the fuel flow, most effective.
My gut tells me that if the car starts and idles to operating temp that the ignition system is probably functioning satisfactorily. Ditto for engine/mechanical.
Frustrating, I know.
R Wedge TR8 woes...electric? Triumph 10
mctriumph SOLD!! Tr7/ Tr8 transmission Triumph Classifieds 0
S For Sale 1980 TR8 Group 44 Tribute Triumph Classifieds 0
P Wedge Starting problems TR8 Triumph 3
tr6nitjulius Wedge Rare TR8 Triumph 0
Got_All_4 Wedge Looking at a Local TR8 For Sale Little Ruff Triumph 1
Hamish Racing TR8 IMSA GTO around Spa Racing 0
MadMarx Wedge Dijon 2019 - Triumph TR8 IMSA GTO Triumph 0
MadMarx General TR Spa Summer Classic 2019 - TR8 IMSA GTO Triumph 1
MadMarx Brands Hatch - Triumph TR8 IMSA GTO Racing 0
MadMarx General TR Brands Hatch - Triumph TR8 IMSA GTO Triumph 0
MadMarx Wedge The IMSA TR8 is ready to go again Triumph 7
MadMarx Wedge IMSA TR8 video with some roar Triumph 0
MadMarx Triumph TR8 at Spa Racing 0
MadMarx Le Mans - YTCC - Triumph TR8 IMSA Racing 1
B Gold TR8 Waxhaw N.C. Spotted 2
MadMarx Wedge Canadian Group 44 TR8 at Hockenheim Triumph 2
MadMarx Wedge TR8 IMSA at Le Castellet Triumph 1
J Wedge TR8 research before purchase Triumph 16
MadMarx Wedge Custom Header IMSA TR8 Triumph 14
S Wanted TR8 with blown motor or no motor Triumph Classifieds 0
T Wedge Triumph TR8 for Sale - 1,020 miles Triumph 3
S Wedge tr8 front end Triumph 0
S Wedge TR8 starter solenoid details? Triumph 3
S Wedge Tr8 manual Triumph 2
S Wedge Need help with TR8 no spark Triumph 7
MadMarx Wedge IMSA TR8 goes on Salzburgring Triumph 6
S Wedge TR8 Starter wiring help needed Triumph 18
Rut Wedge TR8 for sale Triumph 1
MadMarx Spa Summer Classic - IMSA TR8 Racing 0
MadMarx Wedge Spa Summer Classic - IMSA TR8 Triumph 7
B Wedge tr8 oil pressure switch number needed Triumph 3
G Wedge TR8 Classified? Triumph 0
G Wedge New to me TR8 Barn find Triumph 8
MadMarx Wedge IMSA TR8 - a recent photo Triumph 3
MadMarx Wedge IMSA TR8 - Spax on the rear axle Triumph 3
W TR8 brake aclipers on a Spridget Spridgets 38
MadMarx IMSA TR8 on the NĂĽrburgring Racing 3
MadMarx Wedge IMSA TR8 is racing Triumph 7
tr7andtvr Wedge TR8 Rotor Specs? Triumph 0
T Wedge Riddle me this guys | TR8 SMOG test issue Triumph 13
tr7andtvr Wedge TR8 calipers? Triumph 3
tr7andtvr Wedge Tr7, Tr8 or SD1 3.08 rear needed.... Triumph 25
Mickey Richaud General TR TR8 Folks Triumph 0
T Wedge TR8 parts car Triumph 3
philman Wedge Tr8 on local craigs list Triumph 11
Airfix Wedge TR8 Zenith Stromberg carbs slow deceleration Triumph 1
Darrell_Walker Wedge Rimmer's front rally spoiler installed on my TR8 Triumph 22
JFS Wedge TR8 Hazard Flasher Triumph 15
