Wedge tr8 starter installation question
vicno
I bought a new starter for my TR8 from TRF. It is shaped differently than the original one and has "made in Japan" on the box. It bolted up without a problem but now the catalytic convertor won't go back on because it hits the starter. Has any one else had this problem? How did you fix it?
Thanks.
tr8todd
When the stock TR8 starter goes bad, most people opt for either the later stock Rover starter or one of the aftermarket starters. Both options are smaller, lighter and are considered gear reduction high torque starters. They work very well, and are almost essential if you opt for a larger displacement or higher compression replacement engine. They will turn over a warm high compression stroker motor with ease. Never heard of the problem you are encountering. I guess it's getting harder to find stock cores to rebuild. Maybe the fact that I have 5 or 6 of them isn't helping the situation. I suggest you return the one you have and look for one of the high torque starters.
DNK
Todd, Any chance the one from TRF is suggested to be a Hi Torque variety?
What's the part #
Is it GRS106 by any chance?
WedgeWorks
What position is the soleniod in? Stock TR8/Rover past 1976 are on the side if looking from the fron about 9 O'Clock position. If you have one where the soleniod is at the 6 O'Clock position then this is a high torque pre 1976 starter for a rover V8. That will most likely hit the starter. Now the Japan thing sounds like you got a mut-starter.
V
vicno
You are correct, the TRF part number is GRS106. I did a little web searching and found a picture of my starter. On this website it is advertised as a Rover part. You can see from the picture how the solenoid created a problem.
WedgeWorks
Well if I was you I would return it stating the application is incorrect period! Then go on ebay and buy a used high torque rover starter the tiny new ones that go for about $50 to $75 used.
DNK
Hey, before you send it back ,I have one of Woody's in my garage and I will compare measurements if you can provide a pic and #'s along side.
Mickey Richaud
:iagree: That's what I have in mine. Smaller, lighter, and not prone to overheating like the originals. Lots of them around.
V
vicno
I should have asked the forum BEFORE installing this one. With a little help from a BIG hammer I was able to customize the catalytic convertor so everything is happy. Thanks for everyone's comments.
Mickey Richaud
Gotta love those custom installations! :smirk:
S Wedge TR8 starter solenoid details? Triumph 3
S Wedge TR8 Starter wiring help needed Triumph 18
S Wedge tr8 starter swap with a 2000 discovery starter Triumph 7
S Wedge TR8 starter dead spot? Triumph 26
JFS Wedge TR8 Starter Wiring Triumph 4
T Wedge TR8 Gear reduction starter Triumph 2
mctriumph SOLD!! Tr7/ Tr8 transmission Triumph Classifieds 0
S For Sale 1980 TR8 Group 44 Tribute Triumph Classifieds 0
P Wedge Starting problems TR8 Triumph 3
tr6nitjulius Wedge Rare TR8 Triumph 0
Got_All_4 Wedge Looking at a Local TR8 For Sale Little Ruff Triumph 1
Hamish Racing TR8 IMSA GTO around Spa Racing 0
MadMarx Wedge Dijon 2019 - Triumph TR8 IMSA GTO Triumph 0
MadMarx General TR Spa Summer Classic 2019 - TR8 IMSA GTO Triumph 1
MadMarx Brands Hatch - Triumph TR8 IMSA GTO Racing 0
MadMarx General TR Brands Hatch - Triumph TR8 IMSA GTO Triumph 0
MadMarx Wedge The IMSA TR8 is ready to go again Triumph 7
MadMarx Wedge IMSA TR8 video with some roar Triumph 0
MadMarx Triumph TR8 at Spa Racing 0
MadMarx Le Mans - YTCC - Triumph TR8 IMSA Racing 1
B Gold TR8 Waxhaw N.C. Spotted 2
MadMarx Wedge Canadian Group 44 TR8 at Hockenheim Triumph 2
MadMarx Wedge TR8 IMSA at Le Castellet Triumph 1
J Wedge TR8 research before purchase Triumph 16
MadMarx Wedge Custom Header IMSA TR8 Triumph 14
S Wanted TR8 with blown motor or no motor Triumph Classifieds 0
T Wedge Triumph TR8 for Sale - 1,020 miles Triumph 3
S Wedge tr8 front end Triumph 0
S Wedge Tr8 manual Triumph 2
S Wedge Need help with TR8 no spark Triumph 7
MadMarx Wedge IMSA TR8 goes on Salzburgring Triumph 6
Rut Wedge TR8 for sale Triumph 1
MadMarx Spa Summer Classic - IMSA TR8 Racing 0
MadMarx Wedge Spa Summer Classic - IMSA TR8 Triumph 7
B Wedge tr8 oil pressure switch number needed Triumph 3
G Wedge TR8 Classified? Triumph 0
G Wedge New to me TR8 Barn find Triumph 8
MadMarx Wedge IMSA TR8 - a recent photo Triumph 3
MadMarx Wedge IMSA TR8 - Spax on the rear axle Triumph 3
W TR8 brake aclipers on a Spridget Spridgets 38
MadMarx IMSA TR8 on the NĂĽrburgring Racing 3
MadMarx Wedge IMSA TR8 is racing Triumph 7
tr7andtvr Wedge TR8 Rotor Specs? Triumph 0
T Wedge Riddle me this guys | TR8 SMOG test issue Triumph 13
tr7andtvr Wedge TR8 calipers? Triumph 3
tr7andtvr Wedge Tr7, Tr8 or SD1 3.08 rear needed.... Triumph 25
Mickey Richaud General TR TR8 Folks Triumph 0
T Wedge TR8 parts car Triumph 3
philman Wedge Tr8 on local craigs list Triumph 11
