PATR8
OK, I have to admit defeat. Early this spring my lights all of a sudden stopped flipping up. The lights were spliced in when I bought the car and I never had trouble with them so I left them as is. I checked the fuses... nothing, and I changed nothing. I checked the connections and then the left one would go up but not down. Beleiving I have ADHAD, I just grew fustrated and wound them up and down manually until I swapped my spare set of motors in. I tested them up before I installed them and they both worked. Once in, neither worked, swappped in the original lights, neither worked.
Now, 9 months later, I forget what wires go where so here is what I have, can anyone match the wires with their mates?
Driverside
Light loom
Black w/ green stripe
Red w/ Green stripe
Green
Car loom
Black
Black w/ white stripe
White w/ a blue stripe
Brown w/ blue strip
Brown w/green
blue w/ green
Red w/ yellow ( fog lights I beleive)
Passanger Side
Light Loom
Red w/ Green stripe
Blue w/Green stripe
Car Loom
Blue w/ Orange stripe
Blue w/ Black stripe
Black
2 blue wires into on female connector
2 Brown w/ blue stripe on one female connector
I will let every one know I check the switch, used a jump between connectors and this still did not resolve any problems.
I would hope someone has this memorized, I have a factory manual and the colors just do not match up with what they had listed
Thanks for the help
Driverside
Light loom
Red w/ Green stripe
Green
Car loom
Black
Brown w/ blue strip
Brown w/green
blue w/ green
Passanger Side
Light Loom
Red w/ Green stripe
Blue w/Green stripe
Car Loom
Black
Thanks for the help
