swift6
tdskip said:swift6 said:The pressure sending unit is on the oil pump, which is external, opposite (above) the spin on oil filter. Right underneath the alternator.
Thanks Shawn - so I checked and the send is still there and feels firmly attached, but it is hard to tell.
When the senders go what signs or visual indicators do they provide?
When mine failed, it leaked a lot of oil. Not in the spectacular way that yours did though. Other than that, there was no other sign. My oil light never came on because the pressure loss wasn't enough to trip it.
With the info Mickey posted though it brings up another possibility. If your sending unit is on the external pump then those shiny threads could be to a plug for the oil gallery. Especially if they moved the sending unit to that area. If that is what was there and it fell out it would be an oil geyser.
You could always fill the sump with oil, disconnect the distributor so it won't start, and turn it over until you get oil pressure. Then see if oil is coming out of that hole or out of the sending unit. Cranking RPM shouldn't spray the engine bay anymore but should identify the leak area.
