GBRandy
My valley pan seal in the back sprung a leak...
To replace that I needed to pull the plenum & intake. So they went off to be powder coated along with the valve covers.
Once the valley pan gasket is out I can then see the hydraulic cam followers.
I can pop off the rocker assemblies pretty easily and pull the push-rods out....
The cam shaft and the entire internal engine is completely original.
I have a set of new hydraulic cam followers that just arrived from Rimmers.....
Should I put them in? Do I need to "prime" them if I do?
