RSMTR8
OK, here is the deal. The car is running great. But when I drive at night, that is another story. Here is what happened tonight. I start the car, then turn the headlight switch on, and the headligts "dance" for like 25 - 30 seconds, and just when you think they are going to disco the night away, they finally stay up! But the car tried to die, I stayed on the gas for a minute or 2, and then it stopped trying to die. So I began to drive home, and everything was fine, I then noticed that the clock on my radio had reset, and all the radio station that were programed were gone. That definetlyt happened durig the startup electrical deal. I was almost home, when I hit a small bump in the road, and what do you know the light when out, and the headlight danced again for like 15 seconds. All the lights went out breifly, dash lights and all! So where do I begin?! I know my realys are good, replaced them about 3 months ago. The switch is also brand new. Oh, here is the other odd thing. If the car is NOT running, and you turn on the headlights, the passanger side goes up, then 2 seconds later, the drivers side goes up, and they stay up!, no big dance. So whats the deal only when the car is running, do they go disco on me! HELP! I have checked and re checked all my grounds. I even added one per suggestion from someone here in the fourm to the rear passenger side lights where there is a connector. I have replaced the battery terminals on the battery as well. I also recently replaced the alternator with a lucas 85A unit, but I had all these problems before the new alternator.
Thanks,
Rod
Thanks,
Rod
