Wedge TR8 fill neck on gas tank
racer_x
Does anyone know if the fill neck (from the gas cap to the tank)on the 1980's Triumphs or on the TR8/TR7 was galvanized?
Mine has a little rust here and there. I wire brushed it off, it looks great. I was wondering if there was any coating I could use to keep it from rusting again when I reinstall it.
tr8todd
I am pretty sure it isn't galvy. The top and bottom sections are soldered together. Solder won't stick to galvy. If you heat that area up, you can take them apart and remove the little flapper door that always breaks and drops down covering the fuel opening.
racer_x
racer_x
That's great info!
I was staring at the flap wondering how to clean it.
Any ideas to keep it from rusting again? Should I just POR 15 it?
WedgeWorks
I justed loked at my recently removed tank and filler neck and it has the typical anodized/silvery-gold plating more so silver on the outside. Now on the inside it was just straight silver and I had a little bit of rust at the top but Im not reusing it! So if you can clean it and coat it with something you should be good. Now if you sdo the inside be careful because gas may remove the coating.
tr8todd
I would leave it alone. But if it really bothers you, remove it, wire brush it, remove the little flap since it's out, paint it and reinstall it. The trick is getting the three screws at the top out. They have a tendency to seize from rain water gathering in there. Remember it also attaches to the gas tank rubber fill hose inside that black panel in the trunk with a hose clamp. Reinstallation is a major pain and might require dropping the tank a little.
racer_x
racer_x
I dropped the tank because it was rusty, so I have everything out anyway.
I am having trouble getting a new fuel pump though- I was hoping to cross reference one locally, but haven't had any luck.
WedgeWorks
For the fuel pump its self I have found there are about 20 similiar pumps that look all the same but either have a different hose connection or strainer/filet sock. They were used from the 1964 Buick special up to the mid 80ies buick and chevys. I know Woody at The Wedge Shop has the right replacement which includes the sock filter for about $70. I have found from trying different ones that they are the right fit but way too loud like a continuous buzzing. I think the last one I bought weas about $50 without the filter sock and that was another $15. The other issue is many autopart stores just do nto carry them or they obsolete and cannot be ordered and finding them online is a gamble.
racer_x
racer_x
Thanks guys. Todd nailed it. I cross referenced the Napa part, and got a pump and sock filter at Advanced Auto Parts. $39 for pump and $14 for the sock filter. I should of just ordered it from Woody and got the exact one. The auto parts store had several pumps, that all looked the same. So I may be taking a chance on GPM.
I am wire brushing the brackets and removing the scaly varnish and rust form the parts.
I also took apart the fill neck, de-soldered it, removed the flapper and the funnel piece it attaches too. Then cleaned it all up with a wire brush : )
https://tr8progress.blogspot.com/2010/01/gas-tank-refurnishing-part-1.html
No more rust!
tr8todd
After a little searching, I found the Delphi version on Amazon.com with the sock for $27.77. I bought a couple of them. The Delphi crosses over to the Airtex pump that I believe most places carry. Turns out the TR8 pump has the same specs as one I need for my BMW. BMW wants over $200 for the same pump. No surprise there. On the BMW it is used as a lift pump to get the fuel up to a secondary higher pressure pump. Same as on the TR8 fuel injection cars.
racer_x
racer_x
I wonder what if I have enough pressure in this one to get the fuel bowls filled. I have the stock carb set up, but will probably move to a 4 bbl, 390 CFM but may want something higher.
WedgeWorks
The stock TR8 carbs fuel pump will easily push enough fuel for a 4 barrel. Remember these pumps are used on anything from a 4 cylinder up to a V8 so no worries at all for keeping up with your right foot!
DNK
Specially if ya drive like a sissy. :laugh: :laugh:
mctriumph SOLD!! Tr7/ Tr8 transmission Triumph Classifieds 0
S For Sale 1980 TR8 Group 44 Tribute Triumph Classifieds 0
P Wedge Starting problems TR8 Triumph 3
tr6nitjulius Wedge Rare TR8 Triumph 0
Got_All_4 Wedge Looking at a Local TR8 For Sale Little Ruff Triumph 1
Hamish Racing TR8 IMSA GTO around Spa Racing 0
MadMarx Wedge Dijon 2019 - Triumph TR8 IMSA GTO Triumph 0
MadMarx General TR Spa Summer Classic 2019 - TR8 IMSA GTO Triumph 1
MadMarx Brands Hatch - Triumph TR8 IMSA GTO Racing 0
MadMarx General TR Brands Hatch - Triumph TR8 IMSA GTO Triumph 0
MadMarx Wedge The IMSA TR8 is ready to go again Triumph 7
MadMarx Wedge IMSA TR8 video with some roar Triumph 0
MadMarx Triumph TR8 at Spa Racing 0
MadMarx Le Mans - YTCC - Triumph TR8 IMSA Racing 1
B Gold TR8 Waxhaw N.C. Spotted 2
MadMarx Wedge Canadian Group 44 TR8 at Hockenheim Triumph 2
MadMarx Wedge TR8 IMSA at Le Castellet Triumph 1
J Wedge TR8 research before purchase Triumph 16
MadMarx Wedge Custom Header IMSA TR8 Triumph 14
S Wanted TR8 with blown motor or no motor Triumph Classifieds 0
T Wedge Triumph TR8 for Sale - 1,020 miles Triumph 3
S Wedge tr8 front end Triumph 0
S Wedge TR8 starter solenoid details? Triumph 3
S Wedge Tr8 manual Triumph 2
S Wedge Need help with TR8 no spark Triumph 7
MadMarx Wedge IMSA TR8 goes on Salzburgring Triumph 6
S Wedge TR8 Starter wiring help needed Triumph 18
Rut Wedge TR8 for sale Triumph 1
MadMarx Spa Summer Classic - IMSA TR8 Racing 0
MadMarx Wedge Spa Summer Classic - IMSA TR8 Triumph 7
B Wedge tr8 oil pressure switch number needed Triumph 3
G Wedge TR8 Classified? Triumph 0
G Wedge New to me TR8 Barn find Triumph 8
MadMarx Wedge IMSA TR8 - a recent photo Triumph 3
MadMarx Wedge IMSA TR8 - Spax on the rear axle Triumph 3
W TR8 brake aclipers on a Spridget Spridgets 38
MadMarx IMSA TR8 on the NĂĽrburgring Racing 3
MadMarx Wedge IMSA TR8 is racing Triumph 7
tr7andtvr Wedge TR8 Rotor Specs? Triumph 0
T Wedge Riddle me this guys | TR8 SMOG test issue Triumph 13
tr7andtvr Wedge TR8 calipers? Triumph 3
tr7andtvr Wedge Tr7, Tr8 or SD1 3.08 rear needed.... Triumph 25
Mickey Richaud General TR TR8 Folks Triumph 0
T Wedge TR8 parts car Triumph 3
philman Wedge Tr8 on local craigs list Triumph 11
Airfix Wedge TR8 Zenith Stromberg carbs slow deceleration Triumph 1
Darrell_Walker Wedge Rimmer's front rally spoiler installed on my TR8 Triumph 22
JFS Wedge TR8 Hazard Flasher Triumph 15
aeronca65t TR7 / TR8 on Garden State Parkway - NJ Spotted 0
