Todd, I have a temp gun, so those questions can be answered next week when I have some time to run it and do some testing. The thermostat is a 160 (I think) and the possibility of going to a pusher is better now with the condenser out of there.
Ideally a fan shroud would be nice. The TR6's have them and they funnel all of the air directly into the radiator, so I was surprised that the TR8 didn't have something similar when I first looked under there. I may also fashion the air dam to fit back under the front end, with the ends cut off to accommodate the new fiberglass front end. That will help push air up there while I'm running, but will not help the idle situation much.
When I had the car at NE Dyno for the last (and first) runs, he said the the exhaust gas temps were OK along with the A/F ratio and the timing was right on the money. It never got above 1/2 on all of the dyno runs, but we were jamming air down the front grille with his industrial floor fans.
Like you said, probably a lot of little things, so it's time to pick them off, one by one.
