Wedge TR8 - 3 months in
Darrell_Walker
Tomorrow will be three months since I got my TR8.
If you read some of my previous posts about the car, you may know that my plan is to use it as a daily driver. It hasn't quite made it to that point yet, but at this point it has more to do with the logistics of getting it out of the garage past the rest of the fleet.
When I started thinking about a wedge, everyone said to get an 8. At the time I had only really thought about a 7 (and hadn't driven either). I do have to say that I think everyone was right. I still haven't driven a 7, but the 8 is so smooth compared even to modern 4 bangers that it isn't even a fair comparison. And the low rumble of the engine is something you just don't hear much anymore.
This past weekend I fixed a leaking lower radiator hose, and while checking out that work I noticed fuel leaking from the fuel rail. After shutting down the engine to contemplate what would need to be removed to replace all of the little hoses to the injectors, I decided to check the clamps. Sure enough, the clamps were quite loose, and a little snugging up stopped the leakage. That, along with fixing the slow coolant leak really helped reduce the "after run smell". Can't hurt fuel economy, either. But perhaps explains why the top of the engine is so nice and clean!
There is still lots of little project to do. One other thing I did was to pull the passenger door panel to tighten up the door handle. Turns out one of the nuts was gone, and the other was very loose. I replace them with some nylon nuts, so that shouldn't work loose again.
So in the next month or so I'll probably sell my other daily driver, and jump into this adventure!
DNK
Darrell, I have a fix for those stinkin hoses and will give you a call
TR4nut
Good catch on the fuel - a friend of mine in our club here lost a beautiful fi TR8 when it went up in smoke on the highway. After a couple of years licking his wounds he wound up getting a replacement car with strombergs.
Darrell_Walker
Darrell_Walker
tdskip said:
So where is the thank you gift to all of us enablers? grin
I put my wife in charge of that - watch your step :smile:
Darrell_Walker
Darrell_Walker
Sure, this morning is good.
Darrell_Walker
Darrell_Walker
Well, I was a little premature in declaring victory over the coolant leak. After nearly a week of daily driving, my low coolant light is on again. I can't find any evidence of where it is leaking. It must be a very small leak, as it is only about a cup down in coolant, and I've had no overheating issues.
I may just throw some Alumaseal in the system.
Darrell_Walker
Darrell_Walker
Just noticed the typo, I used nyloc nuts.
Actually, I just had to correct that! Thanks spell-checker!
This was the outside door handle, BTW.
swift6
I'm six years in to using my TR8 as my daily driver. Passed 175,000 miles a few weeks ago. Stock 3.5 is still running very well. Have gotten very used to motoring along in a higher gear at low rpm. Downshifting and hearing the V8 come to life still hasn't gotten old either.
Darrell_Walker
Darrell_Walker
Hi Shawn,
Good to hear! Definitely very different than my 4A.
I may have found my other leak. I still don't see anything, but there was a bit of an antifreeze smell around the small hoses that take coolant to the intake plenum, one of the clamps was fairly loose, and that connection also looked like the hose might have slipped on the pipe a bit.
swift6
Very different. I used my TR6 for quite a few years as my main vehicle. My TR8 is a coupe so it is even more different and ultimately more useable year round in Colorado. It has been a Colorado car since new and effortlessly travels from 5,000 feet in altitude over passes of 12,000+ feet with regularity. Occasionally I'll head up Mt. Evans to the parking area ar 14,134 feet. It is all around a very useable car, especially for a 33 year old sports car.
Darrell_Walker
Darrell_Walker
Well, the fuel leak fix of tightening the clamps was too good to be true. I found that they were also leaking on the intake side of the plenum, where you can't easily tighten them, and the ones on the other side were starting to leak again.
Since the hose was of unknown quality and vintage, and the clamps were the wrong type, I invested in 3 feet of 5/16" FI rated fuel hose and 30 proper FI hose clamps. Which set me back quite a bit at the auto parts store! In fact, they had to order in more clamps because they usually only stock 10.
I got a tip that the plenum could be removed without disconnecting the coolant lines, so that made me happy not to have to drain the radiator yet again. Got is all assembled again, and no leaks to be seen. Well, after I tightened one clamp that I missed!
I also found my other (or another) coolant leak, there was a small drip from the top hose/radiator connection. But as I was pondering how to possibly get in there and check the clamp, it stopped. I had put Alumaseal in on Friday, but hadn't run the engine yet. After a test drive it does seem to be holding.
Darrell_Walker
Darrell_Walker
Thanks, Paul.
It is very gratifying to see the progress. I try to do at least one little think every day to improve the car, sometimes it is as simple as adjusting a door or tucking a bit of upholstery back where it belongs.
Still a few larger sized jobs I want to get to, but that list is getting short.
Brosky
This is why they are called "labors of love".....
mctriumph SOLD!! Tr7/ Tr8 transmission Triumph Classifieds 0
S For Sale 1980 TR8 Group 44 Tribute Triumph Classifieds 0
P Wedge Starting problems TR8 Triumph 3
tr6nitjulius Wedge Rare TR8 Triumph 0
Got_All_4 Wedge Looking at a Local TR8 For Sale Little Ruff Triumph 1
Hamish Racing TR8 IMSA GTO around Spa Racing 0
MadMarx Wedge Dijon 2019 - Triumph TR8 IMSA GTO Triumph 0
MadMarx General TR Spa Summer Classic 2019 - TR8 IMSA GTO Triumph 1
MadMarx Brands Hatch - Triumph TR8 IMSA GTO Racing 0
MadMarx General TR Brands Hatch - Triumph TR8 IMSA GTO Triumph 0
MadMarx Wedge The IMSA TR8 is ready to go again Triumph 7
MadMarx Wedge IMSA TR8 video with some roar Triumph 0
MadMarx Triumph TR8 at Spa Racing 0
MadMarx Le Mans - YTCC - Triumph TR8 IMSA Racing 1
B Gold TR8 Waxhaw N.C. Spotted 2
MadMarx Wedge Canadian Group 44 TR8 at Hockenheim Triumph 2
MadMarx Wedge TR8 IMSA at Le Castellet Triumph 1
J Wedge TR8 research before purchase Triumph 16
MadMarx Wedge Custom Header IMSA TR8 Triumph 14
S Wanted TR8 with blown motor or no motor Triumph Classifieds 0
T Wedge Triumph TR8 for Sale - 1,020 miles Triumph 3
S Wedge tr8 front end Triumph 0
S Wedge TR8 starter solenoid details? Triumph 3
S Wedge Tr8 manual Triumph 2
S Wedge Need help with TR8 no spark Triumph 7
MadMarx Wedge IMSA TR8 goes on Salzburgring Triumph 6
S Wedge TR8 Starter wiring help needed Triumph 18
Rut Wedge TR8 for sale Triumph 1
MadMarx Spa Summer Classic - IMSA TR8 Racing 0
MadMarx Wedge Spa Summer Classic - IMSA TR8 Triumph 7
B Wedge tr8 oil pressure switch number needed Triumph 3
G Wedge TR8 Classified? Triumph 0
G Wedge New to me TR8 Barn find Triumph 8
MadMarx Wedge IMSA TR8 - a recent photo Triumph 3
MadMarx Wedge IMSA TR8 - Spax on the rear axle Triumph 3
W TR8 brake aclipers on a Spridget Spridgets 38
MadMarx IMSA TR8 on the NĂĽrburgring Racing 3
MadMarx Wedge IMSA TR8 is racing Triumph 7
tr7andtvr Wedge TR8 Rotor Specs? Triumph 0
T Wedge Riddle me this guys | TR8 SMOG test issue Triumph 13
tr7andtvr Wedge TR8 calipers? Triumph 3
tr7andtvr Wedge Tr7, Tr8 or SD1 3.08 rear needed.... Triumph 25
Mickey Richaud General TR TR8 Folks Triumph 0
T Wedge TR8 parts car Triumph 3
philman Wedge Tr8 on local craigs list Triumph 11
Airfix Wedge TR8 Zenith Stromberg carbs slow deceleration Triumph 1
Darrell_Walker Wedge Rimmer's front rally spoiler installed on my TR8 Triumph 22
JFS Wedge TR8 Hazard Flasher Triumph 15
aeronca65t TR7 / TR8 on Garden State Parkway - NJ Spotted 0
