Wedge TR7 upgraded 4 row radiator
johnrip
Does any use the upgraded radiator that rimmers sells for the tr7. It uses four rows instead of three. I was wondering if it looks the same, and is the same size? Does it really improve cooling?
Have yours redone by a rad shop. Don't know what Rimmer charges,but with the freight can't be cheaper.
I had mine recored and rebuilt locally and am happy with the result. I'd bet there's a good shop near you that can suggest options. Be sure and have them install a draincock while they're at it. Locate the best place for it before you remove the radiator, as that may vary with the accesories you may have.
Have them build an oil cooler into it too.
Any good radiator shop can do the recore to 3 or 4 row. Stock is a staggered 2-3 rows. Anything has to better than that!
