Three things come instantly to mind here. One is isn't it funny how vendors find faults in products they don't sell and think the one's they do sell are the best thing since sliced bread. Two, The wedge tops are in general so much better fitting than any other LBC top, that even if you have a poorly fitting one, it will far exceed the weather protection afforded by an MGB or similar top. Three, if your planning on keeping the car, spend the money and buy a Robbins top. They really are worth the extra money in my opinion. The canvas ones are beautiful. If you aren't sure about keeping the car, just buy an ebay special. You will get several years out of it. They are not too difficult to install. Be careful not to oversize the holes in the header rail when you drill out the rivets. It the top doesn't come with a new header rail vinyl piece, go to a fabric store and buy some. Use good automotive glue like 3M, not some cheap general purpose spray glue. The frame mounts with adjustable bolt holes in the sides. Make sure they are in the middle of the adjustment range when you are installing the top. If the top ends up too tight or too loose, you can move the frame up or down to compensate. Good luck.
