mgb4tim
Me and my 6 year-old assistant took our first trip out of the neighborhood this evening.
It was about a 16-mile trip out through town, and back in through the country.
There's a shimmy around 45 mph, but settles out around 50 - I think the tires might just need balanced. It's a little heavier on left turns, but only at that speed. There's no shimmy beyond that, even turning left. With that in mind, I don't think I'm concerned that the tie rod end is failing.
BTW, this is the same trip that I take to work when I don't want to take the interstate.
I can tell the timing is still a little off - so much for trying it by ear. If I can find that blasted timing mark, I'll be able to to set it right. And, is sounds like there's a heat shield rattling.
I rebuilt the passenger side window assembly last fall, and it's perfect. Now, I really need to do the driver's door - the rattle is driving me crazy.
The shifter felt a little warm, but it's been a while sine I've driven a small 4-cylinder stick, so it may be normal. But, all 5 gears worked fine. Is there an easy means to check the fluid level in the transmission?
All in all, my daughter loved it, and has already requested that I take her to the pet store tomorrow in it. I told her, "only if it's not going to rain."
To wrap it up, <span style="font-weight: bold"><span style="font-size: 14pt"><span style="color: #CC0000">thank you for all the help getting this beast back on the road</span></span></span>.
