mgb4tim
Have been putting some time into the TR7 the past week to get her running, just in time for winter. Got the water pump replaced and installed a new the cold-start injector - huge starting difference.
But it's acting up. When it wants to start, it cranks over 2-3 times and fires. Runs for a while, then dies. Read tonight's story below.
I park it with the charger coz I've been cranking it alot, trying to coax it to start.
I go out in the AM, starts right up. After work, starts right up. If it stalls while running after a while, I crank and I get poop.
Tonight, I start it up, back and forth the driveway I go any number of times. Through the grass, around the garage, up the street to my other driveway. Back down, back up.
This time, I go down into the grass, start back around the garage and...poop!
Crank it, and it seems weak. So, I get the orange cord, plug in the charger, cover it with a tarp - hasn't rained in weeks, starts tonight and I have a ripped back window.
As I was driving it, I saw a faint glow from the alternator light. Could I possibly not be sending enough juice from the alternator and be driving long enough on the battery? then, when the battery's had enough, it poops out?? Does the AC/Delco system require such a high voltage to be stable?
I know, I need to pull the alternator and have it tested. If it needs replaced, are there alternatives, like with my MGB? Less costly and more effective?
I'm sooooooooooooo close to having a driver!
Remember, after sitting for a while on the charger, it starts.
