If it's the one in your profile, yep.
On its way.
On its way.
Mickey, I'm confused: the (time of day) clock is in the upper left of the cluster as you look at the face of the cluster from the driver's seat, so I don't see how it can be upper left in a photo of the backside of the cluster? :confuse:Mickey Richaud said:Here ya go, Don. Clock is upper left in this picture. All gauges and lights have been removed.
Andrew Mace said:Mickey, I'm confused: the (time of day) clock is in the upper left of the cluster as you look at the face of the cluster from the driver's seat, so I don't see how it can be upper left in a photo of the backside of the cluster? :confuse:Mickey Richaud said:Here ya go, Don. Clock is upper left in this picture. All gauges and lights have been removed.
Well, I can honestly say I'm getting close to having gauges again. Everything seems fine in terms of continuity, right up to the multi-connector. So today I finally got the opportunity to take the temp. and fuel gauges out of the cluster, clean up every contact I could, test the gauges while they were out (both worked fine with power applied), reassemble the cluster and install it in the car.Mickey Richaud said:Shorting [the gauges] at the sender should tell you if they're working.
Did you check continuity between the plug end terminus on the dash housing and the gauge connections? May be a broken strip there. Or the multi-connector may have issues.
UPDATE:Yours Truly said:So it looks as if I'll need a new temp. gauge sender (I'm NOT surprised!), and I'll keep a good thought -- for now -- about the fuel gauge sender just being dirty.![]()
