Hi All, I've been trying to fine tune my 1980 TR7 with respect to ignition timing. Under full load the car will miss fire through the higer gears. I've spun the distributor back and forth, moved it a gear tooth etc. The only thing left I can think of is to replace the springs such that the arms in the distributor it will not fly out so far. Rimmer bros lists the part at RTC1863, Is there a source in the US for these parts. I do not really want to install a new distributor (mallory) since it idles fine and runs pretty good, except when I really get on the gas for a while as I run through the gears. Any advice would be appreciated. Thanks and Regards, Andy J
