Wedge tr7 clutch linkage problems
MDCanaday
In responce to a question asked by Dale on a prior topic, there is a cure for the tr7 dragging clutch blues. Drop the slave cyl. out of the way, with your handy migwelder add 1/8in to the release rod end. Test fit for proper free play and repeat if needed. when it is tight ,dress the end and lube it a little before re-assembly. I have done this on several 7s and the results have been great.Just take care to make the end as smooth as it was when you started.
MD (mad dog)
