johnrip
I had my rotors and pads replaced at the end of last season. They worked great, but I had a loud bearing noise. So at the beginning of this season I had the front bearings replaced. The bearing nose was gone, but a very loud brake squeal started after 10 miles. I mean bus loud. I brought the car back, and the mechanic (that I do trust as very good with the car), and he de-glazed the rotors and pads. 15 miles later, full sound is back. I had put on semi-metallic pads from Moss Motors, so I ordered organic pads from Rimmer Bros and had those put on. I also replaced with new shims, pins and clips. They were quiet for about 30 miles and then I have an intermitted rubbing squeak on the driver side, and a squeal on the passenger side. Not as loud as before, but I have to brake hard to avoid the sound (very annoying). I have an appointment to have this looked into. I am thinking new rotors and / or new calipers? Any ideas would greatly be appreciated. Rotors are cheap, calipers are not.:tennis:
