TR6 tr6 windshield replacement
tr6lover
hey guys, got a new windshield and am going to replace it. any advice? how about sealant? i dont know where to get the dum dum from for it. what should i use on it? anyone put it in dry with no sealant? thanks
Randy
kodanja
I used no sealent!
perfect fit no drips!
Brosky
A lubricant perhaps, but no sealant should be required.
kodanja
soapy water and a thin rope is all ya need!
& a two man team!
3798j
Bronze
No sealant here either. Used Armorall and the assistance of two friends positioning the glass as I pulled the coated nylon cord. The trim strip was a little tricky on the curved corners (did'nt want to stay in), but with patience, the installation went surpisingly well.
Gliderman8
I did it twice..... got the first one in 3/4 of the way and I pushed too hard on the corner.....CRACK!
Second one went better. I did not use sealant. Just take your time and use the rope to ease it into the rubber channel.
Best advice is EASY DOES IT.
Adrio
No sealant needed for mine either. Just soap and water. For sure you need two people, my wife and I managed it so you may not have to go far for the second pair of hands.
kodanja
ya' then you can blame her when it cracks!
T
tr6lover
hey guys, im having a problem trying to get the seal on the windshield so then i can attempt to put it on the car. i got the seal from vic. british and im wondering if maybe the rubber is supposed to be contoured more.....did you guys seal the seal to the glass before trying to pop it on the car? im frustrated here trying to get it on and stay on! thanks guys
Randy
MDCanaday
Having done a few hundred over the last 30+years I will throw in my 5cents.The rope must be cotton clothes line,smaller cords can easily tear the rubber.A little tape to hold in the chrome strip is good.Sealing ,if needed, is done after install.However it is getting hard to get the liquid butyl sealer as there are very few rubber set windows on the road today.You can use the dish soap straight up as a lube.I suggest carefull cleaning of the frame,in fact,great time to freshen up the mat black paint!!
MD(mad dog)
hondo402000
rubber seal goes on the glass first, you could use silicon to glue the gasket to the windscreen and tape to hold it and cure over night, then windscreen to frame, like the above post soap and nylon string( put the string in the seals groove all the way around the gasket with the end on the inside of the car i started at the bottom and worke my way around a dental pick help pull the seal in around the corners, be careful cause the nylon roap can rip the gasket if you pull too hard, just go all the way around and get the lip on the inside of the frame and then use some slight pressure on the glass and pound it home, with the palm of you hands and evenly all the way around and it will pop in the frame just take your time hope that helps,
hondo402000
as a side note when i decided to pull the wind screen frame out to sand blast and repaint I tried to get the windscreen out and tried to save the gasket, big mistake, cracked the glass in the process but save the 30 dollar gasket and new glass well at least over 100 bucks, yes i know
laneriddle
Windscreen on my Tr6 is milky looking around the edges. Is it delaminating or something?
what type of glass should I replace it with?
I notice in the parts catalogs prices from about $150 up to $450.
Whats the deal?
thanks
poolboy
The "Triplex" for 450 is the original brand that was installed in factory new cars..desired by some for this fact alone
My replacement came from Moss...'solid tinted' about 180 bucks
The tinting is very light, but noticeable:DRL 004.jpg
mrv8q
^^^^ Handsome TR6!
glemon
Will second the stout course, like a quarter inch cotton clothesline. I used a strong twine, on the theory it would be easier to pull out. Wrong, it can and did break, and more importantly will rip through the rubber gasket. I did one myself years ago and did fine. Second time I screwed up and cracked the glass. Had a guy come and install on site. He used the thicker cord and had it on very quickly, after watching and learning from my mistakes wouldn't hesitate to try again myself. Lube on install with soapy water or Windex as you go. No additional sealant should be needed.
Madflyer
I looked at You Tube and will be doing it this week. One You Tube guy did it himself others had two guys. Soap no sealant air cord seems to be right size cord. corners seem to be the tricky part and go from center bottom each way around up. The filler seemed to be some work one guy used a rubber mallet over tool. From You Tube to this BLOG thank guys. Madflyer
Madflyer
Well I started windscreen today just putting seal on more than an hour with one person. I do not think shape matters much. Just dish soap worked well enough I am letting it sit for awhile to find it self and I needed a brake. So far it is easier than and MG B. because you have to take frame off on a MG B. I will try nylon jump cord . Madflyer
Madflyer
Another day and done. # 1 I think the 1/4 cord is better I used nylon a little smaller and nicked seal at post and visor but still OK. # 2 I used dish soap cut 50/50 water. Seal is hard to install but got it. # 3 The filler You Tube one used a tool another used a rubber mallet. I used a lot of soap in the slot with my hand it slipped right in and corners did OK I will let dry. As for the filler when I took my old one off after many years it was 3 inches short and trim piece did nothing to cover space. I was ounce told to put it in the freezer for a day or so I did that and left it long and marked where I might cut to fit as it is now in a 90 plus deg. garage it is longer already as it got to temp. It is still sitting in soapy water and moves easy. ( NOTE ) go slow and some kind of tool to help cord around press glass as you go lots of soap. I went from tinted glass to clear and with so many road miles the chips were bad in to the sun and night lights. Best of luck Madflyer
S TR6 71 TR6 Windshield Replacement Triumph 6
NAROMF TR6 TR6 WINDSHIELD REPLACEMENT Triumph 12
M TR6 Windshield Trim TR6 Triumph 14
EWD TR6 74 TR6 - Rear and windshield frame color Triumph 2
TR3TR6 TR6 Triumph TR6 Windshield seal on ragtop Triumph 6
TR3TR6 TR6 TR6 top frame windshield seal. Triumph 5
TR3TR6 TR6 Tr6 windshield glass removal Triumph 6
G TR6 TR6 dash and windshield frame removal Triumph 13
I TR6 help with TR6 windshield wiper arm removal Triumph 6
I TR6 TR6 windshield frame bent? Triumph 8
D TR6 TR6-windshield frame to bady sealer Triumph 3
I TR6 Right TR6 windshield bracket Triumph 2
M TR6 TR6 windshield paint color Triumph 12
M TR6 Windshield Frame Color, TR6 Triumph 7
Webb Sledge TR6 Windshield [TR6] Triumph 12
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
R TR6 Crazy Ignition Failure in TR6 engine… Triumph 7
mctriumph For Sale 69 Tr6 Triumph Classifieds 1
B TR6 TR6 block decking Triumph 2
A TR6 How many fuel filters-TR6 Triumph 25
Got_All_4 General Tech TR6 Transmission Troubles Pops Out of 3rd gear Triumph 2
J TR6 Repadding TR6 frame Triumph 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
M TR6 Sorting out new TR6 Triumph 10
S TR6 '72 TR6 distributor issues Triumph 3
R TR6 Limit Mechanical Advance on TR6 distributor? Triumph 8
B TR6 TR6 convertible top frame Triumph 0
K TR2/3/3A The TR6 gearbox Ist gear.... Triumph 1
tr6nitjulius For Sale TR6 tail light assemby & Resurfaced/New Ring Gear Flywheel Triumph Classifieds 0
tr6nitjulius TR6 TRIUMPH TR6 Triumph 7
S TR6 New tr6 purchase Triumph 31
nichola TR6 Hot spot on cylinder head - 1973 TR6 Triumph 2
R TR6 Heater control bezels TR6 Triumph 2
L For Sale 1974 Tr6 for sale Triumph Classifieds 0
tr6nitjulius TR6 TR6 Parts Visualization Triumph 0
Got_All_4 For Sale 1969 TR6 Driver Seat Triumph Classifieds 0
R TR6 TR6 Choke Cable Triumph 11
Got_All_4 For Sale TR6 TR250 TR4 parts for sale Triumph Classifieds 2
B For Sale TR6 Carburetors Triumph Classifieds 0
R TR6 TR6 Triumph 6
Chrisc9 TR6 TR6 brake light Triumph 6
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
SherpaPilot TR6 Unidentified fitting on TR6 Engine Triumph 3
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
AngliaGT ANOTHER TR6,& an MGB Spotted 0
