TR6 Tr6 windshield glass removal
TR3TR6
Has anybody removed the windshield glass on a TR6 without cutting the rubber seal around it? I need to replace my front windshield frame and have a relatively new rubber seal on it and would like to reuse the seal. Any ideas would be greatly appreciated.
trrdster2000
Terry, do you want to buy a new rubber or windshield??? You can get one or the other out of the frame and if it has not had black sealer injected, you may be able to work it out. Don't use anything metal, (screwdriver) to pry with and start in a top corner with a bunch of wooden wedges(door and window shims) and you might get lucky. If you are paying someone to do it, buy a new rubber.
Wayne
TR3TR6
TR3TR6
Thanks Wayne, no I want to move the windshield and seal to another frame. I didn't consider the wooden wedges. I was trying to get it out using some plastic wedges and I was working on the top corner of the windshield. It may be a two person job; I was trying it by myself. I may end up having to purchase another seal. Trying to save some bucks!
glemon
Pull the plastic trim piece out and simply push the windshield out the front. I have done it that way a couple times have somebody on the outside to "catch" it. Use soft force spread over a large area. Like hands (or feet). Don't force it, but as I recall it didn't take excessive force to get it done. Might be different if a sealer was used.
P.S. if you have already gotten it started with the wooden wedges it will be even easier.
Greg
trrdster2000
Terry, we all try and save a buck or two. Wish I had all the money I have saved, but then again, wish I had all the money I had to spend because I broke what ever it was or a spring went bong and no one saw it. LOL
Wayne
TR3TR6
TR3TR6
I know what your saying Wayne, I went and ordered another seal, with my luck I would probably break the windshield which cost a lot more than the seal.
glemon
I would add on the push it out method that I would put towels or a tarp or something over the hood, but it really doesn't pop out just kind of eazes its way off.
Nothing wrong with trying to save the seal, if it survives and looks good you can use it, if it doesn't you can order a new one. Windshield should be pretty tough just don't use any sharp metal implements in its removal (or re-install).
M TR6 Windshield Trim TR6 Triumph 14
EWD TR6 74 TR6 - Rear and windshield frame color Triumph 2
TR3TR6 TR6 Triumph TR6 Windshield seal on ragtop Triumph 6
TR3TR6 TR6 TR6 top frame windshield seal. Triumph 5
S TR6 71 TR6 Windshield Replacement Triumph 6
G TR6 TR6 dash and windshield frame removal Triumph 13
I TR6 help with TR6 windshield wiper arm removal Triumph 6
I TR6 TR6 windshield frame bent? Triumph 8
T TR6 tr6 windshield replacement Triumph 18
D TR6 TR6-windshield frame to bady sealer Triumph 3
I TR6 Right TR6 windshield bracket Triumph 2
M TR6 TR6 windshield paint color Triumph 12
NAROMF TR6 TR6 WINDSHIELD REPLACEMENT Triumph 12
M TR6 Windshield Frame Color, TR6 Triumph 7
Webb Sledge TR6 Windshield [TR6] Triumph 12
R TR6 Crazy Ignition Failure in TR6 engine… Triumph 7
mctriumph For Sale 69 Tr6 Triumph Classifieds 1
B TR6 TR6 block decking Triumph 2
A TR6 How many fuel filters-TR6 Triumph 25
Got_All_4 General Tech TR6 Transmission Troubles Pops Out of 3rd gear Triumph 2
J TR6 Repadding TR6 frame Triumph 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
M TR6 Sorting out new TR6 Triumph 10
S TR6 '72 TR6 distributor issues Triumph 3
R TR6 Limit Mechanical Advance on TR6 distributor? Triumph 8
B TR6 TR6 convertible top frame Triumph 0
K TR2/3/3A The TR6 gearbox Ist gear.... Triumph 1
tr6nitjulius For Sale TR6 tail light assemby & Resurfaced/New Ring Gear Flywheel Triumph Classifieds 0
tr6nitjulius TR6 TRIUMPH TR6 Triumph 7
S TR6 New tr6 purchase Triumph 31
nichola TR6 Hot spot on cylinder head - 1973 TR6 Triumph 2
R TR6 Heater control bezels TR6 Triumph 2
L For Sale 1974 Tr6 for sale Triumph Classifieds 0
tr6nitjulius TR6 TR6 Parts Visualization Triumph 0
Got_All_4 For Sale 1969 TR6 Driver Seat Triumph Classifieds 0
R TR6 TR6 Choke Cable Triumph 11
Got_All_4 For Sale TR6 TR250 TR4 parts for sale Triumph Classifieds 2
B For Sale TR6 Carburetors Triumph Classifieds 0
R TR6 TR6 Triumph 6
Chrisc9 TR6 TR6 brake light Triumph 6
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
SherpaPilot TR6 Unidentified fitting on TR6 Engine Triumph 3
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
AngliaGT ANOTHER TR6,& an MGB Spotted 0
A For Sale 1974 TR6 Triumph Classifieds 1
