TR6 tr6 wheelstuds
jussie
planning on running wheel spacers on my tr6, so i need longer wheelstuds. i already have really expensive lugnuts that fit the factory wheel studs, does anyone know the dimensions of the stock studs? mostly i need the knurled diameter and the knurled length. i'd take the studs out and measure them, but then i couldent drive the car (is my only car). also, a part number for wheelstuds that would fit my critera would be fantastic!
please help!
I know a couple of people run them Stay tuned ,they'll pop on.
Not familiar with Crownsville
Dorman 610-114 measures 7/16"-20x1 21/32". I had to trim a little off with 1/4" spacers.
You will have to bore the holes to 9/16".
The actual knurl length is about 7/32". The base of the head to the top of the threads is about 7/16".
I used these on the fronts. I haven't done anything to the rear yet.
When I converted my wheels to wires, I needed to get the shorter studs so they wouldnt rub against the inner housing of the rim.
They sell them at VB.
