TR6 TR6- water leaking through tail lights
ichthos
Hello,
I need more help again. It looks like I have two places left that water is leaking into my trunk: the right tail light and left tail light. I put in new gaskets between the lenses and body, but it is still leaking. So, my question is do I need to just tighten down everything down more, or do I also need to use some kind of gasket seal? If I do need a gasket seal, what kind do people suggest?
Thanks,
Kevin
G
Do NOT use a gasket sealant. When you take the assembly off again in the future, you will take the paint with it. Just crank down evenly on the small nuts inside the trunk evenly across the tail light housing until the foam gasket is almost or maybe even touching your body. This will stop the leak, assuming you have new gaskets.
TR6oldtimer
Water can leak past the lens, the Brits even provided a drain(usually plugged up) for this eventuality, but it can also get in there through the seam between the fender and the body around the tail light box, the trunk lip, or other joints. From inside the trunk area check for rust up under the top of the body and the tail light box.
T
Tinster
Line your trunk with newspaper and masking tape.
Close the trunk lid.
Spray hose water along the lowest portions of the trunk
from the exterior. Stop frequently, open the trunk
lid and look for water stains on the newspaper.
Work you way upward to higher elevations with frequent
stops and open the trunk to inspect.
The water test should define your problem to a point
of entry.
d. /bcforum/images/%%GRAEMLIN_URL%%/rolleyes.gif
I
ichthos
Thanks guys. I ran a hose all around the trunk area. I fixed the area where it came through in throught the filler neck. It is not coming in through the fenders or around the trunk seal that I can see. The trunk had no plugs on the bottom of the trunk area, and now I can see why. The previous gaskets were either missin or rotting. Water is definately coming in from the lens and the gasket between the light housing. I did put in new gaskets. I'll try taking them apart and retighten a little better and see what happens.
Kevin
B TR6 1973 tr6 water pump Triumph 4
T TR6 tr6 water pump trick? Triumph 4
P TR6 tr6 water pump Triumph 3
wingsandwheels TR6 TR6 water pump finish Triumph 0
wingsandwheels TR6 TR6 water pump replacement Triumph 12
TR6oldtimer TR6 TR6/250 water pumps and a dumb PO [me] Triumph 4
AngliaGT TR6 TR6 Water Pump Help Triumph 2
T TR6 TR6 water pump gasket - also use sealer as well? Triumph 9
2wrench TR6 Which water pump for my April 1974 TR6 Triumph 3
2wrench TR6 TR6 Water in the oil; blue/gray smoke. Triumph 5
I TR6 water leak in 69 TR6 trunk Triumph 6
F TR6 Replacing Water Pump on TR6... Triumph 6
T TR6 TR6 water pump installation - use gasket sealer Triumph 7
T TR6 Best place to pick up a new water pump for '71 TR6 Triumph 7
R6MGS TR6 TR6 engine compartment water channel Triumph 7
F TR6 Changing 73 TR6 Water Pump Triumph 0
tr6web TR6 Water pump mouting - TR6 Triumph 12
tr6web TR6 TR6 Water Pump Question Triumph 4
Stinky TR6 TR6 Water Pump Question Triumph 6
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
P TR6 Horn issue 1974 TR6 Triumph 5
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
R TR6 Crazy Ignition Failure in TR6 engine… Triumph 7
mctriumph For Sale 69 Tr6 Triumph Classifieds 1
B TR6 TR6 block decking Triumph 2
A TR6 How many fuel filters-TR6 Triumph 25
Got_All_4 General Tech TR6 Transmission Troubles Pops Out of 3rd gear Triumph 2
J TR6 Repadding TR6 frame Triumph 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
M TR6 Sorting out new TR6 Triumph 10
S TR6 '72 TR6 distributor issues Triumph 3
R TR6 Limit Mechanical Advance on TR6 distributor? Triumph 8
B TR6 TR6 convertible top frame Triumph 0
K TR2/3/3A The TR6 gearbox Ist gear.... Triumph 1
tr6nitjulius For Sale TR6 tail light assemby & Resurfaced/New Ring Gear Flywheel Triumph Classifieds 0
tr6nitjulius TR6 TRIUMPH TR6 Triumph 7
S TR6 New tr6 purchase Triumph 31
nichola TR6 Hot spot on cylinder head - 1973 TR6 Triumph 2
R TR6 Heater control bezels TR6 Triumph 2
L For Sale 1974 Tr6 for sale Triumph Classifieds 0
tr6nitjulius TR6 TR6 Parts Visualization Triumph 0
Got_All_4 For Sale 1969 TR6 Driver Seat Triumph Classifieds 0
R TR6 TR6 Choke Cable Triumph 11
Got_All_4 For Sale TR6 TR250 TR4 parts for sale Triumph Classifieds 2
B For Sale TR6 Carburetors Triumph Classifieds 0
R TR6 TR6 Triumph 6
