I am suffering with a bad vibration which I suspect is in the drive train. It starts about 52mph and is road speed sensitive, indepent of which gear I am in, or even coasting. It appears to be in the right rear?
What I have done so far is swap wheels F/B and L/R. I also replaced the right side half shaft and installed new U-joints in the right shaft. I also have taken the main drive shaft in to a reputable sho and had it dynamically rebalanced ( it was out due to adiition of a grease fitting by PO). The vibration changed slightly after the driveline work, but only a little better.
So I need some help. What am I missing?
