Thanks for all the help and tips on adjusting the valves. I think I have a reasonable plan of action. I adjusted the valves. They were all loose. It seems like using the feeler gauge is an art in itself. I made sure the 0.008 was loose, the 0.010 was snug, and the 0.012 would not pass through. I checked everything twice. I have to wait for my valve cover gasket to start up the engine before I can tell if my engine runs any better. I am going to periodically check the valves every 3,000 miles to see if they need adjusting. When I do feel the need to rebuild them, I will ask for the improved valves, seats and guides. I would guess that the head would automatically have to be surfaced also. It is unclear to me based on the posts if it would be beneficial to "port" the valves (make them larger?)or the cost to do so. My next question is what are symptoms that the valves are too tight or loose? What damage can be caused by the valves being too tight or loose?
Kevin
