I'll second the vote for iron guides, but not the bypass line. IMO as long as the rocker shaft (and passage to it) doesn't get clogged with sludge, the factory metering system delivers just the right amount of oil. But it's worth checking that the passages are clear each time you set the valves.
Note that, if you do go with bronze, they have to be reamed oversize after installation. The bronze expands faster with heat than the cast iron head does, so the guide/stem clearance closes up when the engine is working hard. Without the extra clearance, the guide may gall to the stem or even lock the valve open. To my thinking, the extra clearance pretty well negates any "long life" advantage of the bronze. In effect, you are installing them "pre-worn".
