Tosh
Gentlemen,
Recently completed installation of the nylatron bushes and the front swaybar, both supplied by GoodParts. The handling difference is (to coin a phrase) awesome.
When reassembling the suspension I turned the upper a-arm pivot so that the outer/curved part of the casting is toward the motor. I had previously rebuilt the front with those pieces having the "curve" toward the tire.
I do not remember how they were originally. I think I have pictures of them both ways.
Anyway, It appears that I have now introduced some negative camber to the front suspension. I have liked negative camber (in the proper amounts) ever since "track days" in my GT Mustang.
The measured difference in the spindle locations thru the centerline of the pivots looks to be about 1/4". So that would be roughly 1/4" more negative camber. I did not change the number (1) of shims in the lower wishbone.
Other than tire wear can anyone think of a reason not to have some - camber on this car?
The steering is a bit heavier but the car is eons more stable than before I completed all of this work.
Your thoughts?
Tosh
Your thoughts?
Tosh
