GTP1960
Hello,
i could use some guidance on changing my A type OD tranny oil.
questions:
is the large brass plug/cover at the base of the OD the drain port for the OD?
(Mine has a small leak I think , any suggestions on sealing?)
what is the best way to fill the oil?
the small port on the side of the hump is of no value. To small and out of alignment.
I'm thinking a flex neck oil pump can, under the car, but the manual says 2L capacity.
last question: the OD service manual says sae 30w mineral oil in summer, But no one has mentioned that in past forum post ( last couple years anyway).
so I'm leaning toward valvoline syn. 75-90 gear oil.
Thanks and and best regards,
Guy
questions:
Guy
