TR6 TR6 trunion help - how tight, correct lubricant?
vagt6 said:
Don't use grease in your trunnions, it wears 'em out. :yesnod:
Yup. I've always greased mine and they've only lasted 100,000 miles. O'course they aren't worn out yet, but no doubt another 100,000 would have done them in :joker:
I haven't racked up that many miles, Randall, but when I do grease them, it seems to me that the fresh grease pushes the old grease out and the contaminants along with it. Does that sound reasonable ?
Regarding the use of oil instead of grease, the original owner's manual and the Haynes manual recommend oil in the trunnions. Since most of the factory folks are six feet under (rest their souls ;), we can't know the exact reasons for the oil recommendation although it may be related to the tendency for the old-type greases to solidify over time.
In my experience with antique cars and motorcycles I've found that it often pays to go with the manufacturer's recommendation, since their engineers designed the vehicle.
However, as Randall indicates, grease works well in his car. I think that if the car is used as most of our Triumphs (i.e., on clean, dry, paved roads), it probably makes no significant difference. But if the car is driven in very dusty/dirty environments (i.e., dirt roads; mud; wet conditions, etc.), oil is probably the best trunnion lubricant for the reasons I stated above: it's less likely to retain solid particles and become an abrasive agent.
And as always, YMMV. :yesnod:
I use 00 grease, a semi-sluid grease with EP protection used in agriculture. Comes in a drum or small 10 oz. tubes like most marine EP and can be pushed in with the tool above. Google 00 grease
Just for clarity, my car was a TR3A, and the factory recommendation up to the TR4 was for grease. Grease makes a very effective dirt trap, so I doubt there is any outside dirt getting down inside where one would worry about wear. Wear particles would be a different story, as they are generated right where the wear occurs. But adding grease should push them out eventually; and wear particles have not appeared to be a problem for me.
I do drive mostly on dry, paved roads, as that is what most roads are around here. But I have been out in the dirt probably more often than most owners take their Triumphs; as the mountain roads around here are one of my favorite places to play and they frequently turn to gravel/dirt without warning. Hanging the tail out and throwing a rooster tail IS a lot of fun (but likely explains why my paint jobs don't hold up very well
This is a local friend of mine, I didn't make that run. But I would love to go some day!
