Hello,
I am doing a complete overhaul of both trailing arm areas. The driver side trailing arm brackets had 3 spacers behind each trailing arm bracket. I had read in one of my manuals that this is the maximum number of spacers that should be used. When I removed the passenger side there were five spacers behind the inside TA bracket, and four spacers behind the outer TA bracket. I plan on taking my car in for a four way allignment when I am done, but should I put the same amount of spacers back in this area even though it exceeds the maximum suggested amount of spacers? Thanks,
Kevin
Kevin
