TR6 TR6 Top rubber window seals
cmacmillan
Can someone describe/post a pic/PM me the correct positioning of the rubber seals on the side rails of the top?
I'm replacing the hood and was meticulous with bagging/labeling hardware and didn't notice that the rubber pieces were asymmetrical.
Much obliged!
Gliderman8
Here you go... let me know if you need additional photo's and I'll take them for you...
Further note: the seal is "J" shaped, and the tail of the "J" points inwards on each side.
cmacmillan
cmacmillan
Ah-ha! Absolutely perfect, Thanks!
...and interestingly, the opposite of what I was going to do! Always helps to ask.
Gliderman8
Happy to help...
YYCDave
I'd like to respectfully disagree. The purpose of the "J" portion is to provide a flexible seal for the side window to compress against, therefore it should be on the outside.
Gliderman8
Well, that is a surprise to me to then!
I guess that's what happens when you inherit problems like this from previous owners.
I took them off and re-installed them the same way I got them not knowing any better.
Looks like I will have a little project over the winter.
Sure hope its not to late for cmacmillan.
Thanks for pointing that out.
mallard
Dave's got it right they go to the outside.
cmacmillan
cmacmillan
Hahahaha! That'll teach me to check the forum over the weekend! I did the final install last night. I have to think it's not going to be a huge issue - especially given it's just sitting stationary in a garage for the foreseeable future. Also installed a snap upside down - I'll have to take it all off when I paint it. Right now I'm just pleased it looks pretty good for a DYI job...will post a pic.
cmacmillan
cmacmillan
actually, while I'm here - any tricks to getting that header rail rubber seal into place? The channels seem to small and sharp to slide it in...not to mention the gaps between the side channels and the centre channel.
Gliderman8
Just got mine turned around- It was pretty easy... I pulled out the rubber then used some warm soapy water and they slid back into the channels.
Again, sorry for the confusion.
MadRiver TR6 Rubber seal on top of grill on TR6 Triumph 5
B TR6 TR6 convertible top frame Triumph 0
EWD TR6 TR6 top dash trim paint Triumph 2
W TR6 Tr6 soft top lnstall Triumph 5
D TR6 Soft Top Selection 1976 Triumph TR6 Triumph 5
Rut TR4/4A TR4a or TR6 top frame? Triumph 4
K TR4/4A Black marks on a TR4A/TR6 vinyl top boot cover? Triumph 4
TR3TR6 TR6 TR6 top frame windshield seal. Triumph 5
TomChar TR6 '74 TR6 - Broken Top bow Triumph 1
K TR2/3/3A Is the 4A Gearbox Top Cover the same as the TR6 Top Cover? Triumph 2
TR6oldtimer TR6 TR6 soft top frame not aligning with windows Triumph 1
D TR6 76 TR6 Soft Top Triumph 2
k60djg TR6 TR6 Hard Top Fitting Instructions Triumph 5
C TR6 Truly Top-Flight TR6 V8 Triumph 1
B TR6 Putting a Tr4 top on a Tr6 Triumph 14
G TR6 How dry does your TR6 Hard Top keep you? Triumph 2
V TR6 Top, aftermarket plastic/fiberglass for TR6? Triumph 6
W TR6 how to lowering 1972 TR6 soft top Triumph 4
G TR6 Spotted TR6 Hard top for sale Triumph 0
ScottTR6 TR6 Advice for new TR6 Soft Top Triumph 9
K TR6 TR250/4 top on a TR6? Triumph 11
I TR6 TR6 hard top advice please Triumph 3
bcbennett TR6 TR6 top cover/plastic snaps Triumph 5
wangdango TR6 TR6 convertible top "tab"??? Triumph 1
wangdango TR6 TR6 convertible top woes..... Triumph 3
eschneider TR6 what is TR6 hard top worth? Triumph 7
G TR6 TR6 Top Triumph 6
I TR6 TR6 convertible frame top help Triumph 1
K TR6 Custom Hardtops - aftermarket top TR6 Triumph 11
eschneider TR6 What does this top boot / cover fit? TR6? Triumph 4
B TR6 71 TR6 Covertible top hardware Triumph 7
B TR6 TR6 Convertible top Triumph 16
amcboy TR6 Question about TR6 top velcro attaching... Triumph 3
C TR6 TR6 Top Speed? Triumph 42
prb51 TR6 Top Gear TR6 moment Triumph 9
R TR6 Ebay TR6 Hard top Triumph 10
jjbunn TR6 Hot news: TR6 on Top Gear Triumph 12
T TR6 tr6 top seals Triumph 8
T TR6 tr6 top seals Triumph 2
cutlass29 TR6 TR6 convertible top cover...help! Triumph 4
2wrench TR6 Looking for tips on folding soft top TR6 Triumph 11
delisaj TR6 TR6 Replacement Convertible Top Triumph 23
tomshobby TR6 Free TR6 top Triumph 11
YankeeTR TR6 top gear TR6 video....required viewing Triumph 7
M TR6 TR6 Hard Top Seals Triumph 0
V TR6 TR6 Hard Top Triumph 13
I TR6 Best place to buy rag top for TR6? Triumph 4
trrdster2000 TR6 TR6 top question Triumph 7
TR674 TR6 TR6 Soft top Triumph 6
H TR6 Spring Washers for Soft top latches TR6 Triumph 3
