The old girl (1973) seems to run "best" with timing at 18 deg ATDC. Seem that it should be in the range of 6-12 deg BTDC. I had the dizzy rebuilt by Jeff and carbs rebuilt by the other Jeff (excellent jobs by both, and very helpful). The extra plumbing on the carb side has been removed (canister, anti-run on etc.). The rear carb bottom is plugged as is the dizzy.
Was thinking about setting timing using vacuum gauge and not worrying about what the timing mark indicated. However, the PO "rebuilt" the engine and I have some concern that the cam and crank are not quite in sync.
"best" as used above is defined as sounds good, runs smooth, idles a bit high, has less power than I think it should.
Any thoughts as to how best to proceed?
Thanks in advance, Eric.
Hi Guest!
