TexasKnucklehead
So I'm out for a TR6 drive in the wonderful weather. Minding my own business at a light and I hear "Smile". There is a blond in the car in the next lane with her passenger window down, pointing her camera at me. Is that a TR4?
After I run some errands, I find myself having to pull out very hard into traffic as someone is signaling to turn into the same parking lot. I pull out into 3 lanes of traffic, into the right lane, hard enough for both rear tires to sound an audible alert, but cut my acceleration short when I hear an unusual clicking, monotonically incrementing with engine speed. As I shift into second gear, the noise dissipates. At each subsequent red light, I gingerly pull out to hear the noise again, always disappearing as soon as I shift to second. The sound seems to be coming from the passenger rear hub.
At home I lift the rear end. Spin the wheel, check for play in the half shaft universals and look for a sloppy wheel. Nothing. I can lightly hear the noise when the car is in neutral, and much quieter if the clutch is pressed in. If I allow the car to drift backwards down the driveway in neutral there is no noise. If I pull back up in second gear, there is no noise. If I drift backwards in second gear with the clutch pressed in, there is no noise. If I drift backwards in first gear with the clutch in, it ticks loudly the whole way back. If I pull back forward in first gear, the noise is there. Reverse gear seems to be normal.
I overhauled this transmission a few years ago and checked the oil level early this spring. (There's still the usual drips of oil under there, so I know it's not empty.) I hate to pull the trans again, but I can't see another option.
Any idea what I've broken?
