TR6 TR6 Steering Lock
oxendine
What's the easiest way to unlock the steering wheel on a 72 Tr6 when one has no keys? Remove ignition switch?
Thanks, Donnie
yes that would be correct, easiest is to pull the tach and speedo out take the bolts and nuts off that hold the whole ignition switch to the column and your Free!
Hondo
and but the way I never knew mine had a steering lock, I always left the key in the ignition switch and when I took the key out one time it locked up, I thought I had done something wrong but figured it out soon after that
Hondo
To remove the lock will take cutting the special bolts off.
Replace with socket head screws
The heads on the bolts from the factory were "break-away"... on mine they were not tighten enough for the heads to break away so they were easy to remove.
