SkinnedKnuckles
Well that 30 minute job only took over 2 hours! The old one came out in pieces - 2 of the opposing aluminum "wedges" completely separated from the coupling.
Of course, the new one was a tad too big, so after 10 minutes of fiddling got out a band clamp. Put the squeeze on it and got the screw/bolts/ ground strap on.
It was then I saw the squirm - about 1/4" between sides. No wonder those pieces separated. Moved the upper bracket about 1/8" until there was slop in the dust covers (I guess that's what they are) on the upper piece. Absolutely could not get any purchase from the lower rod that goes down to the u-joint at the pinion. After 2 tries decided to try later when the ball joints go in.
I wasn't pleased with the extreme counterbore depth, but what more can I say. Seems to be a flex coupling now anyway.
