TR6 TR6 spring pan/wishbone arm help
ichthos
I am following Tinster's article on the front end rebuild. Is there some reason why I can't just bolt the wishbone arms to the spring pan first, attach the pivit brackets, and then just bolt the brackets in place?
Thanks, Kevin
:confuse: :confuse: How are you going to get the spring in??
The pan is removable so you can get the spring in and out. Please don't tell me you're going to have the spring captured in there while you jack up the lower "A" arm and try to bolt it in place!!! :eeek:
In a word, YES.
