tr6web
I can't for the life of me figure out this issue.
Engine starts right up and runs, lots of power, but it is missing at any speed. I've tried turning/retarding the distributor (which has all new points, rotor, condenser... also got a new Lucas Sports Coil), and checking for vacuum leaks using starter/carb cleaner (no leaks I can find, engine doesn't respond to the carb cleaner anywhere I spray it). Carbs have new seals too, but I didn't check to confirm nothing happened since they were put in last year.
Is it timing? If so, can someone explain in laymen's terms how to check? If not, what else can I try? Thanks everyone.
Hi Guest!
