hondo402000
Ok guys I am getting to the end of putting my car back together and the reverse lights have never worked, so since I replaced the motor mounts, and the back was easy to get to by pull the trans cover, and what do I find,,,, I see there are no wires to the switch. Check the switch and no fuctiooooooney Thank lucas that you can take the switch apart, its frozen, rusted up, so get the switch back working, but no wires. I found a green( hot when switch is on but no green brown wired to be found that goes to the Reverse lamps
question did the wires go from the engine compartment to the switch or from the interior to the switch?
thanks
HOndo
thanks
HOndo
