TR6 [TR6] removal of front transmission seal
GuyShark
Member
How do I removed the seal on the front end of the transmission?
Its pressed in there, and its leaking bad. I have already damaged the seal trying to removed it (I have a new replacement).
It looks like the one thats in there is a small, thinwall steel sleeved pressed in.
Do I just gotta heat the piece up and pry?
TIA.
If you mean part #53 from the Moss Motors page then these are typically destroyed when you remove them. You have to pry them out or use a seal puller. Just remember which side the lip faces.
Moss on-line Catalog page
Yes, its part #53.
Seal puller? Hmm. I dont believe I've ever seen one.
I guess its ok to pry it out, as long as I don't damage the housing?
The transmission goes back in this weekend! /ubbthreads/images/graemlins/driving.gif
I got it out, but it wasn't pretty.
Small screwdriver & deadblow hammer.
New one is in, however the transmission install has been postponed. My buddy broke 2 exhaust bolts on his 76 Firebird, so I've been messing with that all day. (and the next few days).
Thanks.
