SherpaPilot
I believe I have a little excessive free play (float) in the rear bearings of my 72 TR6. In preparation for this check, I did a little reading. The manual calls for checking the bearing end float with a dial micrometer. When correctly adjusted, it should be within 0.002 to 0.005. That is pretty precise. The book also tells me the axle shaft must be removed to adjust the end float. Is there an easier way to do this without the purchase of a depth micrometer?
