TR6 TR6 Problem
bigbadbluetr6
Today my dad was driving my TR6 to meet me at the taping of Pinks at Heartland Park Topeka, KS. He left the car where he meet his buddy because of a weird clunking noice. Jacked up the car when we got it home and everything looks normal. What could this be? It sounds like it is coming from the passenger side in the IRS. Could it be the u-joints? I hope not because I've changed them once or could it be the hub? How much play is there suppose to be in the rear wheels when you shake them back and forth?
DougF
When is the clunking occurring? Is it continuous or only happening at specific times?
It could be anything from a broken frame to a ujoint, bearing, differential or half shaft.
If you can create the noise while the car is in the air, that will simplify the search. Since the one ujoint is difficult to access, I would start from the outside and work in and inside working out, leaving it for last. If Mr. Murphy has anything to do with it, it will be that ujoint.
MarkT
Hi Eric,
Whenever I hear "clunking noise" and "passenger side, rear," I think differential mount (ask me how I know!). The front passenger side mount is the one that usually goes, either by cracking or fully breaking, creating a clunking sound when driving (especially on gear changes). It can be pretty hard to see in there, but with the wheel off you can (just) see that bracket when the car is up on jacks. If you make sure the car is really secure, you can get your hand up in there and feel for any damage.
I hope this helps, and I hope its not the mount! A complete pain and somewhat pricey to fix....
Cheers,
Mark
Paul Johnson
Good idea to put the car up and have a very close look at the two rear crossmembers. Just had cracks in mine near where the shock mountings are. Scary noises are now gone.
bigbadbluetr6
bigbadbluetr6
The noice happens when the car is in motion. It doesn't matter if power is applied. I've had my front mount break before and its a different noice then that. The noice is a clunk clunk clunk and gets faster with every evolution/more speed. Kinda sounds like a U-joint from the sound of things. Well I'm going down to the garage and getting ready to operate/work on the stinken TR. /ubbthreads/images/graemlins/smile.gif
swift6
You might have to pull a drum and insprect the shoes and springs too. Since it speeds up as the car does it definitely points to some part of the rotating mass.
bigbadbluetr6
bigbadbluetr6
Well i've got both rear wheels off and the drums. Spring and pads look good but haven't inspected them thoroughly. I've taken both half shalves out and looked at the U-joints. I can't tell the difference if the U-joints are bad or not. THere seems to be no play when twisting them back and forth. Where the housing that holds the barring are not smooth they are making like a scratching sound when turned on the bench. Could that be the clunk clunk clunk noice at road speeds?
G
[ QUOTE ]
[/ QUOTE ]
Watch your mouth! She will hear you!
Are the bolts that hold your hubs onto the swing arm secure. Wouldn't hurt to check the torque on them. Very often these little jewels will work out of the aluminum swing arm. Remember, they are only fine-thread bolts screwed into soft aluminum. Might be a good time to check each one and consider redoing them with HeliCoils or equivilant.
Bill
trrdster2000
Eric, as a bit of information, when new Ujoints are installed they should flop around on their own with no tightness. Sometimes you have to spring back the yokes with a hammer to make everything be in the proper place and aligment, if you have had one that was hard to get out and a press was used, they will wear out in no time if the yokes aren't sprung back. Wayne
bigbadbluetr6
bigbadbluetr6
Well after looking at all the U-joints I've replaced they all seem to be alright. After putting the car back together the sound is still there. It makes me wonder if its the driveshaft U-joints. Those have no been replaced. When I get a chance to be back home dad and I will attack those 2 U-joints in search of the problem.
RomanH
I have a similar noise in my car. Thought it was comming from the passenger side toward the rear of the car. Could not figure it out. Took a friend with me for a drive and he said the noise was coming from in between the seats. Had him drive so that I could listen and sure enough the noise was from in between the seats. Turned out that the trans output flange bolts where hitting the tunnel. Havn't fixed the problem yet as I am going to be doing a engine rebuild this winter.
tr6nitjulius TR6 TR6 No 1st/2nd problem/solution Triumph 4
Got_All_4 TR6 2nd Gear Bush Problem TR6 Looking at Steel Triumph 12
J TR6 72 TR6 starter problem Triumph 10
C TR6 TR6 TURN SIGNAL PROBLEM Triumph 13
T TR2/3/3A Is there any problem in putting TR6 plastic wheel covers & TR6 lug nuts on TR3 wheels Triumph 4
T TR6 Problem with Clutch on 1976 TR6 Triumph 12
T TR6 TR6 Starter problem Triumph 8
G TR6 TR6 Clutch Problem Triumph 22
A TR6 carb problem 73 tr6 Triumph 10
D TR6 New poster, TR6 clutch problem Triumph 10
Gliderman8 TR6 Troubleshoot a TR6 Fuel gauge problem Triumph 36
M TR6 1976 TR6 Ignition problem Triumph 6
T TR6 Electrical Problem with TR6 Triumph 11
F TR6 triumph tr6 clutch problem Triumph 14
C TR6 69-TR6 horn problem Triumph 4
martx-5 TR6 TR6 Alternator Problem Triumph 1
AngliaGT TR6 TR6 - Starter Problem Triumph 14
P TR6 76 TR6 fast idel problem Triumph 5
veale001 TR6 TR6 Distributor problem........................... Triumph 39
bigbadbluetr6 TR6 TR6 Brakes Problem Triumph 18
bluemiata90 TR6 TR6 clutch issue, Possible bleeding problem ????? Triumph 4
hondo402000 TR6 figured out my low brake peddle problem TR6 Triumph 1
bigbadbluetr6 TR6 TR6 idling problem Triumph 4
B TR6 TR6 starting problem Triumph 24
AngliaGT TR6 Found the TR6 Brake Problem Triumph 5
T TR6 TR6 with overheating problem - what to inspect Triumph 7
hondo402000 TR6 Marker Light Problem too TR6 Triumph 1
A TR6 TR6 Clutch Problem Triumph 11
hondo402000 TR6 TR6 electrical problem continue Triumph 23
mabbott TR6 73 TR6 Sputtering problem? Triumph 17
hondo402000 TR6 TR6 towed on Sat night, electrical problem Triumph 9
R TR6 TR6 Brake Balance Problem Triumph 23
hondo402000 TR6 starter Problem TR6 Triumph 6
R6MGS TR6 TR6 hazards...again....diff problem thou Triumph 3
B TR6 TR6 Vibration Problem Triumph 9
I TR6 TR6 Coolant System Problem Triumph 5
Brosky TR6 TR6 Clutch knocking noise problem [not mine] *DELETED* Triumph 2
Paulus TR6 TR6 Speedometer problem in transmission housing Triumph 5
Brosky TR6 Horn problem with TR6 Triumph 12
T TR6 Newbie with a TR6 engine problem Triumph 39
M TR6 TR6 Starter problem? Triumph 10
G TR6 Replacement TR6 grill problem.... Triumph 2
RomanH TR6 TR6 Zenith Carb Problem Triumph 5
Slider748 TR6 TR6 transmission removal problem Triumph 12
Cain TR6 Odd Problem - TR6 Boot Lid Triumph 1
M TR6 76 TR6 clutch problem Triumph 3
G TR6 TR6 Clutch Problem Triumph 5
tr6web TR6 TR6 Light exhuast problem Triumph 11
Webb Sledge TR6 Starter & Clutch Problem [72 TR6] Triumph 14
Slider748 TR6 '74 TR6 Idle problem Triumph 3
