gbtr6
Hello, My 74 TR6 isn't running well. I have a Pertronix, Dwell gap dead nuts on 35,I also adjusted the valves, to .010 cold. I have SU HS-6's on it. It hasn't run since more than a year ago. I sispect bad gas but...I started it and it runs on the choke, but only at around 1500 rpm. After that, if I put the choke in, when it's warming up, it doesn't run, drops right off. As an experiment, i took starting fluid and sprayed a shot into each carb. into the front one, immediate reaction, rise in rpm's. Spray the rear one, nothing. This is on the choke, at @1500 rpm's. I'd think I'd get a reaction like the front carb. The throttle shaft rotates. I'm puzzled. Any thoughts???
Thanks,
Perry
Thanks,
Perry
