TR6 TR6 leaking at brake pedal
tr6web
I have a small leak dripping onto the floor that's coming from the brake pedal. Anyone know where it might be coming from and should I check the servo seals/gaskets or master cylinder?
V
vagt6
It's coming from your brake master cylinder. It's probably time for a rebuild, not a difficult job. Fix it now, it will only get worse with time.
Anyone else?
Steven
for sure its seeping along the piston rod on the master cylinder. Forget the rebuild, and get a new unit if you can. Try Victoria British, or the Roadster Factory. Rebuilt master cylinders are just trouble waiting to happen.
healeys4me
Mike, I would get that MC replaced before too long. The job is easy and the cost to replace or repair far outweighs the alternative. . .
Rick O.
And also drain all the brake fluid out of the servo reservoir. I don't see how it is possible to get wet feet without accumulating fluid in the servo too.
jeff3113
I had the same issue 2 years ago. I went the way of rebuilding the cylinder. Parts $18 at Checker auto parts.
I would certainly run some 400 grit around inside the bore to smooth things out. Took a couple hours and on the road!
It was tougher to bleed the lines than anything else.
Good luck
jeff
tr6web
tr6web
Jeff, as a newbie, what is 400 grit? Also, what's the best way to bleed the lines and how and when should I go about doing that? Should I drain the resevoir first, then take it apart? I have all of the manuals for it (just not handy at work) so I'm sure it will walk me through it. But sounds like you have it down, so any walkthrough would be great. Thanks for your time.
Steven
bleeding the lines is easy with the Gunson Eezi-bleed system. Keep your old master cylinder cap to attach to the bleeder hose. You'll have to punch a small hole in the top of it because the kit has a million caps, but not one to fit that big brake master cylinder cap for the TR6. It runs off of pressure from you spare tire, and it flushes the system out like water from a faucet. It's the easiest and most efficient hydraulic bleeder system I've ever used.
jeff3113
You can get the black emery paper with various grit levels - 240, 320, 400. The higher the number the finer grit on the it. Any hardware store or auto supply place will have some. I like using the finer type so it leaves a smooth surface behind after getting debris and rough spots out. I put it around my finger and sanded the inside of the cylinder as far back as I could get. To get the back locations I used a wooden dowel with that sandpaper around it.
You will need to drain the master cylinder and remove the lines attached to it. There are 2 nuts holding it to the brake booster (large metal drum at the firewall). Be VERY carefull with the rags and drips - brake fluid is caustic to painted surfaces. A small interal clip holds the parts of the piston and valve together. When you do get it to that point just make sure you pay close attention to the order of things as you pull it apart. After sanding clean things thoroughly. Installation is basically the reverse of things. One thing to note is when re-installing the new plunger make sure you carefully slide the plunger back in. It should go without binding - although a tight fit.
So, that's an abbreviated explaination of how I did it. I still haven't picked up one of those Eezi-bleed units and should being I do enough maintenance to justify it.
Steven
Gunson's Eezi Bleed system can be purchased from the Roadster Factory, and probably Victoria British. Moss Motors has it also, but their prices are too high.
Bugeye58
Use the proper brake cylinder hone, rather than sandpaper. Run it slowly, using brake fluid as a lubricant, and be sure to clean the cylinder VERY thoroughly afterward.
The hone can be found at any auto parts store, and is inexpensive. It will give you the proper finish in the bore, as well as making sure the bore is round.
Jeff
delisaj TR6 TR6 Leaking brake fluid Triumph 1
I TR6 TR6 - Fuel leaking from bottom of Evaporator Canister Triumph 11
T TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas Triumph 11
T TR6 leaking carb TR6 Triumph 17
hondo402000 TR6 New rear wheel cylinder leaking, TR6 Triumph 0
TRclassic3 TR6 TR6 Leaking oil gallery plug Triumph 5
hondo402000 TR6 Leaking Transmission solved TR6 Triumph 5
I TR6 TR6- water leaking through tail lights Triumph 4
I TR6 TR6 valve cover leaking Triumph 5
Paulus TR6 Coolant leaking from TR6? Triumph 5
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
P TR6 Horn issue 1974 TR6 Triumph 5
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
R TR6 Crazy Ignition Failure in TR6 engine… Triumph 7
mctriumph For Sale 69 Tr6 Triumph Classifieds 1
B TR6 TR6 block decking Triumph 2
A TR6 How many fuel filters-TR6 Triumph 25
Got_All_4 General Tech TR6 Transmission Troubles Pops Out of 3rd gear Triumph 2
J TR6 Repadding TR6 frame Triumph 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
M TR6 Sorting out new TR6 Triumph 10
S TR6 '72 TR6 distributor issues Triumph 3
R TR6 Limit Mechanical Advance on TR6 distributor? Triumph 8
B TR6 TR6 convertible top frame Triumph 0
K TR2/3/3A The TR6 gearbox Ist gear.... Triumph 1
tr6nitjulius For Sale TR6 tail light assemby & Resurfaced/New Ring Gear Flywheel Triumph Classifieds 0
tr6nitjulius TR6 TRIUMPH TR6 Triumph 7
S TR6 New tr6 purchase Triumph 31
nichola TR6 Hot spot on cylinder head - 1973 TR6 Triumph 2
R TR6 Heater control bezels TR6 Triumph 2
L For Sale 1974 Tr6 for sale Triumph Classifieds 0
tr6nitjulius TR6 TR6 Parts Visualization Triumph 0
Got_All_4 For Sale 1969 TR6 Driver Seat Triumph Classifieds 0
R TR6 TR6 Choke Cable Triumph 11
Got_All_4 For Sale TR6 TR250 TR4 parts for sale Triumph Classifieds 2
B For Sale TR6 Carburetors Triumph Classifieds 0
R TR6 TR6 Triumph 6
Chrisc9 TR6 TR6 brake light Triumph 6
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
SherpaPilot TR6 Unidentified fitting on TR6 Engine Triumph 3
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
AngliaGT ANOTHER TR6,& an MGB Spotted 0
A For Sale 1974 TR6 Triumph Classifieds 1
