[ QUOTE ]
I am going to enlarge the carburetor side of the manifold to fit up to some 2" SU's and I thought I would check out the fit of the manifold to the ports to insure they match-up. Then I started to think about doing something to the manifold and since have read many articles about the variables but I have not read and specific articles about the ultimate TR6 manifold. I will be using a spare manifold for my mod and I plan a little dyno time before and after the mod.... it makes sense that if "stacks" on the stock carburetors can make a difference then doing something to the entire manifold would be even better. (maybe)
[/ QUOTE ]
Hi,
Please let us know how it works out. I'm always interested to hear more about this sort of experimentation.
I've read and heard that larger SUs usually aren't particularly helpful, can actually do more harm than good. But that was a more general comment and not specific to TR6. At one time I was considering a 2" set for my TR4 and was talked out of them. The explanation I got seemed to make sense and was that an overly large carb throat of this type (constant vacuum) actually reduces vacuum effect and that can significantly lower gas speeds right on thru the manifold. The argument was that it's better to match the carb size to the engine, rather than go to as large a size as possible.
Since then, I've had some experience running smaller than usual Weber sidedrafts on my car, which have proven quite good for low to mid-range (street/autocross) where most Weber installations go for a big venturi and high rpm performance. Of couse, Weber are a very different design, with a fixed carb throat rather than variable like the SU, not to mention an accelerator pump, and a throat-per-cylinder rather than, siamesed intake. I have 40DCOEs on the car, which was originally speced to use 42DCOEs and 32mm venturis on a stock engine. I ran 30mm venturis at high altitude, and am going to 33-34mm at sea level on a modified engine. Most seem to go to 36 and even 38mm in 45DCOEs. I have added 40mm velocity stacks to these, but haven't had the opportunity to see if theses make a significant difference.
Also, with respect to velocity tubes, I've heard that, although they can be beneficial on Weber, Dellorto, etc., they are little more than "eye candy" on SUs and Zenith Strombergs, do nothing to improve air flow. This seems odd to me since I'd think stacks would work and I'd like to hear otherwise or see some real life results. I've only got a set of Hitachi SU carbs in the spares pile these days, and don't know if experimenting with those would be very applicable to "real" SUs.
The implication is that the SU throat is about as efficient as it can get, and I've read and heard that a little radius at the very mouth can be useful to improve airflow as it comes over that edge, but not full velocity stacks.
This is all just food for thought. I sure don't want to discourage you from trying things. In fact, I'd like to get some real world data on these issues and will be watching for you, or anyone else, to post some results.
Have fun experimentin'!
