vettedog72
I have continued to use the OEM green high tension ignition wires we commonly call spark plug wires. The wires to this day still do very well; no arcs/sparks, broken insulation or other apparent aging.
My question is about the relationship of electronic ignition and the non resistive wires and plugs.I'm thinking the OEM wires may be conducting much more current and putting more load (heat) in the electronic switching module. I have never changed the resistive "run" wire so I know I am not getting the full advantage of the electronic system but I am a little reluctant to make that change with out knowing the effect of resistive vs nonresistant plug wires?
