DougF
I tested the switch and it appears to be in good condition. Installing a new harness and want to make certain everything is functioning properly. The old harness was heavily melted at the switch and ammeter.
Now I'm looking at the ignition switch wiring diagram from my B/L repair manual. I was unable to keep tract of what wire goes where. Both the repair manual and Dan Master's manual indicate the terminal 1 connects to 2 Brown/White wires; terminal 2 connects to 2 White wires; terminal 3 connects to 1 White/Red wire and terminal 4 isn't used.
The problem is terminal 1 only has one spade terminal, while the other three terminals have 2 spades. Terminals 2 & 3 show scratching on both of their spades, while I don't see scratching on terminal 1 from the old quick slide connector.
Does anyone recall what the wiring configuration is here.
Hi Guest!
