My 76 TR6 had a faulty horn relay. I replaced it and it worked - kind of. I was getting 12+ volts on the hot side, but only about 9 volts to the horn. I replaced it again and same result. The horn is only getting 9 volts, not enough to drive it. When I put battery juice directly to the horns, they work fine.
Hi Guest!
